Method: updateAuthCredentialEx
Update command line interface credentials. This operation is similar to updateAuthCredential, but returns a verbose message.
Parameters
Name | Type | Description |
username | string | Username for the credential |
description | string | Brief description of the credential |
loginPassword | string | Password for the credential |
enablePassword | string | Enable password for the credential |
configurationPassword | string | Configuration password for the credential |
type | string | Type of login session, available options are:
-SSH -Telnet |
Returns
Returns a NsWsResult with a structure defined by the following table.
errorCode | int | See the Web Service Error Codes |
errorMessage | string | Error message in readable text |
success | boolean | True if operation is successful |
Execute the following web service with a browser:
https://192.168.30.34:8443/axis/services/NetSightDeviceWebService/updateAuthCredentialEx?username=admin&description=Extreme-Switch&loginPassword=login&enablePassword=enable&configurationPassword=config&type=Telnet
